Hi Experts,
This Product Idea is submitted on behalf of customer ''JOHNSON CONTROLS INCORPORATED"
Currently, if an DWG file is opened in Creo View, the Sheet order will be not same with that in AutoCAD or any other CAD Applcaiton, Creo View always set the "Active Sheet" as "Sheet1".
This behavior will make users confused,especially when uses also named the drawing Sheet as Sheet1,Sheet2...
I have found SPR 7046237, exactly same description and requirement, I also think many other customers will have the same requirement
Please consider changing this behavior in future Creo View Releases
Sun Yi
