Customer use Creo Illustrate 3.1 for creating illustration for engine. There are multiple functions requited below:
1. There is no error prompt and solution info when function operation failed.
2. There is no material gloss mode in Render Mode, hope to add the special and useful method, or add an interface with other Render software including high function.
3. Hope to add the mechanism motion setting, particle animation (such as Rendering fountain, dust, smoke, flame and explosion phenomena), principles of animation, such as the arrow indicates the direction.
4. Add the standard symbol library, such as general 3D tools models, general 2D imagines.
5. Add the anaimation setting about the compatible animation between the schematic and related 3D models.
