Reference PTC Case 13012457
We have Skeleton Parts with Coordinate Systems Only. I'm sure many companies are publishing Datums now.
I can box select or LMB select the datum in the graphics area and the object in the model tree highlights. This is good! However, If I select the part with datums only in the model tree, nothing highlights in the graphics area. Please vote to have Creo View highlght the datum in the graphics area.
