APPLY APPEARANCE PROPERTIES TO SAME OBJECTS EXISTING IN MULTIPLE VIEWS
The Creo View team has added new functionality in 3.1 called "cross select mode" which enables a user to select an object in one view and highlight or select the applicable object in all other views.  I want to further extend this capability by allowing the user to edit the appearance of the selected object in all views.  Using the example image below...I have annotation sets created for 4 different truck variants.  All of them have the same cab and hood.  After opening them up, I want to change the cab to be transparent in all views.  Please vote for this idea if you see benefit in being able to apply appearance settings like color or transparency to multiple views.
2 Comments
BillRyan
The Reference PTC Case is https://www.ptc.com/appserver/cs/view/case.jsp?n=13286799
Note: This may not be viewable to all customers, so an image is attached below.
olivierlp
Community Manager
Status changed to: Archived
