Add Selected surfaces of a part of Selection Sets
0 Kudos
With Creo 6 it is possible to use Selection Sets. Very easy if you are selecting the same thing over and over.
Nowdays you can use this to selects complete parts. This works perfect
Some companies have surface models / omported STEP files / Surface ShrinkWraps in use.
This feature would enhanced if it was also possible to ad different surface selections to the sets.
3 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
Additionally, I invite you to check out this topic where 2 PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
Innoptus_Ferry
11-Garnet
Figure Illustrators for Product Documentation. Automotive Industry.
Creo Illustrate 8.1
Currently it is not possible to make a selection set of a couple of surfaces.  To also Ass surfaces to selection sets would be a great enhancement.2022-04-11 15_45_01-Drill_v8.c3di - Creo Illustrate Professional.png
Company also uses STEP import (surface) / ShrinkWrap / Surface models. These can not be set as geometry.
Surfaces are collered by the engineers. This color hase te be manually removed by the illustrators. And then again selected to give an other color.
Having selection sets available for different surfaces would be great!
FH
olivierlp
Community Manager
Thank you for your idea and the information provided.
