Add ability to invert the mouse wheel zoom functionality to Creo View.
0 Kudos
In Creo View, there is currently no way to invert the mouse wheel zoom functionality in a similar way to that of Creo Parametric's config.pro option use_inverted_mousewheel_zoom.
In both Creo View and Creo Parametric, by default, scrolling up on the mouse wheel zooms out, and scrolling down zooms in. With the functionality inverted, scrolling up zooms in, and scrolling down zooms out; similar to the way zooming works on Google Maps. It would be great if this inversion option was available in Creo View; especially when going back and forth between Creo View and Creo Parametric.
Below is a link to a PTC support article about this topic.
https://www.ptc.com/en/support/article?n=CS272407
2 Comments
Patriot_1776
22-Sapphire I
I agree 100%.  I use Creo, Creo View, AutoCAD, and Solidworks, and THE main issue when switching back and forth between the softwares is the dreaded zoom.  Fix this.
olivierlp
Community Manager
Status changed to: Archived
