Instead of having one sequence with 50+ steps, a user wishes to divide this sequence into several sequences e.g.
From
Sequence 1: Step 1, Step 2, Step 3, Step 4, Step 5, Step 6, Step 7, Step 8
To
Sequence 2: Step 3, Step 4, Step 5, Step 6
Sequence 3: Step 7, Step 8
This is particularly ideal when using PVI in Vuforia Studio.
As of Creo Illustrate 5.1, model parts' location is reverted back to original state when creating new Figures. Therefore when creating Sequence 2 or 3 for upper scenario, a user must manually transform the parts to their last position (in previous Sequence).
If there was a way to use the current model state (with manipulated position) when creating New Figures, it'll make it easier for Creo Illustrate / Vuforia Studio users.
