Add search path option in Creo Illustrate
When importing a creo assembly in Creo illustrate, illustrate only adds parts which are in the same folder as assembly file.
We have a scenario where customer is using standard parts from library folders in assembly and they want to link Creo Parametric assembly with Creo Illustrate.
At the moment illustrate ignore all the parts in different folders, which means customer cannot link creo assembly with illustrate.
If they use PVZ file to bring in all the parts in illustrate, they lose the dynamic link with the creo assembly; which is not acceptable to them.
This subject is described in the following case solution:
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS167883
2 Comments
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
