I have a big structure and I divided that structure in different subdirectories linked to main assembly. When I open that structure it can't open as it is not in the sae directory. and If I put all files in the same directory it will be a miss to me.
For that I suggest to add options file in Creo view as Creo parametric as and add features as "Search path" as
