Additional System Properties for Inserted Attributes
Would like to have the ability to to add the following information to callouts on each figure for automation:
  1. File name
  2. Figure names
This will allow us to have the information on every figure in the PVZ file, so if the file is printed from Creo View or just published to a PF from Illustrate the information will be all printed sheets.
Currently the only way to get the information on each figure is to make note/callout and fill out the information manually. This will cause many errors on drawings and will require revisions to be made to fix the errors.
These attributes are not available in the 3D world but can be extracted using a PDF template when publishing.
3 Comments
agarland
Status changed to: Implementation In Progress
This will be available in the upcoming 9.1 release
agarland
Status changed to: Delivered
agarland
This feature was introduced in the recent 9.1 release of Creo Illustrate.
See the Whats New in 9.1 for more details.
