Callout with parameter and editable text for Creo Illustrate
0 Kudos
I would like to use a callout where I can combine the value of a parameter (imorted with the model from Creo) with editable text.
This is while placing the callout iI would like to add text to the callout in combination with the value of the specified parameter.
[PROE Parameters.MODELNAAM.value]
editable text
1 Comment
mcaruthers
Hello HarrieM,
That's a good idea.  I wonder though... It seems that the parameter data would be stripped out of the model when it comes into Creo Illustrate, thus making it a "light weight" model.  If this is true, I'm not sure that parameter data would be present.
I may be wrong.... just my first thought.
