Compatibility of Animations with Sequences
My colleague is creating animations to export as videos, but I am creating sequences to export to Vuforia Studio for AR. Sequences cannot be exported as videos. We must duplicate the same work, since animations are incompatible with sequences. Can you make transfer between the two types possible? Or allow exporting a video from a sequence?
A Creo Illustrate 5.1 file must either have a sequence or animation, but cannot contain both. When you switch to one, the other is deleted. Content cannot be transferred between sequences & animations either. The only hack to get around this is if you have 2 licenses for Creo Illustrate. Then you can open up two instances of the software (two windows) side-by-side. You can then copy and paste from one Keyframe editor to another. If your goal is to produce videos, and you already have sequences, a hack for this is to click "Preview Sequence" and use a 3rd party screen-recording software. It would be nice however if when working with a sequence, the "Export" button was not grayed-out, but instead offered an option to export to WMV (or MP4) with the understanding that this would "play all steps continuously". Whatever changes are made, it would be nice to see a little more compatibility or transfer-ability between Animations and Sequences within Creo Illustrate 6.0.
Thanks so much,
Wes
4 Comments
DavidW_AR
I would like to chime in to support this idea. Being able to export a sequence developed for AR experiences in Vuforia Studio as a video file would help for developers to share their work with stakeholders that don't have access to Creo Illustrate or View.
agarland
Support for exporting sequences as video files was added in 6.0
There are options to export as one file or each step as a separate file.
agarland
The ability to collapse multiple steps into one and split a single step in two was also added in 6.0, this may help in your workflows as well.
JeffreyCoon
7-Bedrock
Status changed to: Delivered
The ability to export video from a Sequence was added in Creo Illustrate 6.0. In Creo Illustrate 7.0 we added the MP4 format as a video option. You can export each step as a separate video or all as one video.
