Correct Enveloppe (bounding box) feature behavior in Creo View
When using Creo View to calculate the bounding box of a part Inside the PVZ of a higher level assembly  you may face the following problem.
- Parts that have a different orientation than the default assembly coordinate system (parts that are rotated for example), will have a false Enveloppe calculation results.
Here is an illustration of that  behavior :
1/ Calculation of the enveloppe of a rotated clip Inside the pvz of a higher level assembly :
2/ I generate a single PVZ file for the part and i calculate it's enveloppe, the results is different for Y and Z than the calculation Inside the assembly PVZ :
Can you correct the calcultation of the enveloppe of a single part Inside the PVZ of a higher level assembly?
So we can always have the minimal and correct bounding box values??
Thanks in advance.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
