Creo Illustrate - Better Support for Illustrated Parts Lists
Need to be able to include a Parts List or sBOM within a Figure such that the Published Output can "stand on it's own".
API's for Web that enable a dynamic Parts List that is displayed with a Figure for Web do not help when needing to generate paper or paper equivalent output.
Also, need to be able to insert the output of Creo Illustrate into an Arbortext Editor (could be a specialization of DITA within the technical Information Application) such that a Parts List and Image "go together".  Ideally the above API would be built into a specialized XML Schema so that when PTC Products such as Creo Illustrate and Arbortext Editor are used together they not only function together but really work well together.
2 Comments
nordlig
It would totally be great with some additional features such as including the sBOM in a figure.
PTCModerator
Emeritus
Status changed to: Archived
