Creo Illustrate is a great tool for keyframe animations, and getting into VFS using PVZ. But this really limits the re-use into other AR applications.
We could be using a lot of AR with VF Engine and Unity but the workflow is broken as I can't get a FBX animation out of Illustrate and into Unity.
The currently Creo Parametric > Windchill Post Publish > Creo Illustrate pipe works really well, can PTC branch this into both VFS and VFEngine [Unity] to keep and end to end solution for both their AR tools.
I think this would add a lot of value to other organisations piping CAD data into AR using PTC SDK's
Please vote up FBX keyframe animation export for Creo Illustrate if you are facing the same issues.
