Creo Illustrate-Trajectory problem
Please check the attachment. Here I am having the problem about the movements I gave to the parts, in their perticular group and steps.
In video you can see that, I am working in STEP-3. In my NEW TRACK-2 you can see there are so many parts. Th etime periode 5sec. To 7sec. I have one movement for all those parts. In here aprox 16sec. I have gave new movement for other parts from the same TRACK. (JB110018) so it doesn't creat the NEW TRACK. Because my parts are alredy in NEW TRACK-2. Same for other parts in track-2 like 442-601-44 from 18sec. To 20sec.; JB110027 from 20sec. To 22sec.
Now I am creating the another movement for some parts. I have selected two parts 442-601-01 & 442-601-02 but in the tree you can see it makessing; i.e part not a NEW TRACK-3 because the other part 442-601-01 I alredy have used in NEW TRACK-2. So if I need to find this movment the I need go back nad find it according to the other one which I can see in tree.
Now I am going to select four parts and give them movement so you can see the result is it created the NEW TRACK-3 because I have more than two parts. Now the problem is I have selected four parts but in the NEW TRACK-3 you can see only three parts. Because the fourth one is I have used in NEW TRACK-2.
Now I am going to delete the TRACK-3 see what happens. It only have deleted those three parts which are in TRACK-3. But the fourth one from the TRACK-2 with the same movement as this three is didn't delete. So I need go back and check find the part from other TRACKS.
So here are my questions
  1. Can we make the TRACKS according to movements. No matter about the same parts
  2. If I delete the perticular TRACK the parts related to that TRACK should be delete as well.
                          ThankYou!!!
1 Comment
olivierlp
Community Manager
Status changed to: Archived
