In Creo Illustrate you can change the line thickness of the leader, but not the size of the arrow heads of the annotation.
Also the snapping seems does not seem to be at the top of the arrow, this causes the snap to miss it's target sometimes (see arrow pointing the pin of the piston).
These are snapshots from the latest Creo 5.1 F000.
So what would be good improvement:
