Creo View Adapters: Creo/Parametric Simplify Representation should be supported by the Adapter for Creo/Parametric
The Creo/Parametric Simplify Representation should be supported by the Adapter for Creo/Parametric in order to manage different representations in Creo/View.
3 Comments
llie
Luis,
Creo View does support Simplified Representations. It depends on the setting in the Creo View Adapter recipe file if you are publishing thru a CAD Worker. I did a quick test and it works great.
If you are doing a "Save As" to .PVZ in Creo, it uses the export_pvs.rcp file and that setting should be turned on by default because I don't see a Simplified Rep line in the .rcp file. I did another quick test using the "Save As" to .pvz and it worked .
luisPEREIRA
11-Garnet
Hi llie,
For the moment, I can't do the test in a CAD Worker, the IT is in vacation (I check in the rcp Creo local installation and there is no option).
I also do a test manually, perhaps, I didn't have the correct Creo View license or there is a setup in Creo Parametric 2 M100?
I did the test with Creo View 3 Lite and alos with Standard license but I don't see somewhere the different representations, you find it in "Structure" tab?
Tnx
BR
Luis
olivierlp
Community Manager
Status changed to: Archived
