Support was added to Creo 3.0 M060 to allow mixed font output to PDF. (This already existed for printing.) With the new config option enabled, True Type fonts are correctly embedded in the PDF, and non-True Type fonts are stroked. This mixed output provides the best balance between file size and quality while insuring that what is seen on the screen exactly matches what is shown in the PDF. (See CS205845 for more info.)
Please add this same capability to the Creo View Adapters. There needs to be an additional option made available in the recipe editor just like there is in Creo's PDF Export Settings dialog.
Newly added option in Creo:
Missing the same option in the Creo View Adapters recipe editor:
