Currently, a SolidWorks CAD worker will publish the model geometry using the active saved configuration of the model and no others (unless they have been setup as visible objects using the PTC_IS_INSTANCE property). It would be great if the SW options were extended to include Output Author States, like in Creo Parametric and NX, so that additional states were available. Even better would be the option to configure the worker to always publish the model geometry using a specified configuration (e.g. Default) rather than whatever the model was saved with.
