Creo View : Allow pvz exported from Creo Illustrate to have custom columns inside "Figures" tab
When generating a pvz containing sequences from Creo Illustrate, and then reopening it with Creo View.
We have access to the "Figures" tab. This tab dont allow to add custom columns containing the company Parameters/or PTC parameters :
Figures tab should be customizable like Structure or Model tab :
Thanks in advance
1 Comment
Wes_Tomer
This is similar to another idea I saw here about inserting hyperlinks and PDFs.
It would be useful to have custom parameters -- both for the sBOM tab, and the Figures tab (for each sequence step). For instance, an sBOM part could have a parameter weight and the Figures tab could have a parameter instructions or hyperlink. This is essentially a way to augment the sequence steps beyond only containing animations. Defining this sort of metadata is probably best done here -- rather than in some JavaScript file later on in Vuforia Studio (if you are using animations for AR self-guided training).
I would love to see this.
