Creo View - Annotation Control
We would like to use Creo View to view 3D drawings/annotations. It is necessary to have easy access to toggle on/off these annotation from the Main UI. In an .asm file the number of annotation can be very high since all lower level models annotations also show. There show be a shortcut button in the Main UI or the ability to "Customize" the ribbon to include these options.
2 Comments
BillRyan
In the viewable tab from the main LH panel there sometimes can be 100's of viewables available in the list.  At the bottom of the list is a filter bar. Selecting this filter brings up a few settings.  One of them is called "show only viewables associated with selected assembly".  With this turned on you only see the viewables associated with the assemby selected in the tree structure.  I wonder if something similar would work for annotations.
PTCModerator
Emeritus
Status changed to: Archived
