I'm looking for an improved process to apply colors to surfaces in Creo View. In some cases, selecting the part does not result in colors being applied to the part surfaces. If I change the selection filter to "faces", then I can individually select the surfaces to apply colors. The process is very painful when the part has multiple faces. I want to have "box selection" functionality to select these surfaces just like parts. Please vote to have a solution for better selecting surfaces in Creo View
Note: Video only shows selection of a few surfaces. I want the entire part to be one color when complete.
