As we continue to expand our usage of Creo View across the company, more and more groups are consuming and editing the viewable data. As more groups use it, Annotation Sets are being created and stored in Windchill. If you are familiar with the software you may know to check the Annotation Sets tab from time to time. However, if you are a new user, you may not be aware of this. We would like to see a way to either change the default behavior of Creo View to, on open, choose which tab is selected by default (Annotation Sets over Structure, Viewables over Annotation Sets, …) depending on certain administrative or user preferences.
It would also be helpful to have visibility to Annotation Sets, perhaps via a mini viewport, no matter which tab is selected.
