The latest versions of Creo View Adapters for Creo 4 include publishing of cable part features which is very cool. (See picture below showing the features under the part). In Creo Parametric, we have the capability to see the attributes for Logical from and logical to. These attributes are currently not being exposed in Creo View. This enhancement is a request to expose these attributes into Creo View...or Creo Illustrate and Augmented Reality solutions. Enabling this functionality would allow for highlighting of the cable...as an example we could show the ground wire from one connector to another. The real benefit is for validation to verify the first is routed and designed properly. See second picture showing the attributes in the columns that need exposed.
Reference this PTC case for more information - https://www.ptc.com/appserver/cs/view/case.jsp?n=14169005
