It should be possible to add custom notes and annotations in Creo View, the same way as you can do in Creo Illustrate.
In Creo View you can use Note templates which is good, but this requires unneccessary steps compared how it is solved in Creo Illustrate.
In Creo View you require 6 steps to add a note based on a template
In Creo Illustrate you require 2 steps.
Suggestion:
Introduce same solution in Creo View as in Creo Illustrate
