we have succesfully created Czech localization kit for Creo View 2.0 M030.
But the system variable PVIEW_LANG can be set only for 9 supported language.
We have to use a substitute language for its application, we have to choose one of the basic language (which is not used very often in our republic ) and our local. kit is copied/overwrited into it.
We should like to unify this setting with system variable PRO_LANG, this variable is possible to set to Czech language.
Thanks for your understanding
Jana Hubackova
AV ENGINEERING, a.s.
Czech Republic
