One of the key messages in Creo is: any data
But it is not possible to view native data from Creo Elements / Direct.
Creo View is now in version 2.0. Creo View should work as in the key message posted: any data
It´s a little bit crazy, because it is possible to read native data from Creo Elements / Direct in Creo Parametric but not in Creo View.
