I have the following suggestions for Creo View Express OR MCAD.
1.) In Creo view/Express OR MCAD, the Family components could have viewed.
2.) The search path Options of Creo should also be available so that it could easily pick the file from missing Assembly.
3.) The Creo representations should be available to open in Creo View.
4.) The sheet metal Bend & Unbend representation could also be available to view.
Thanks & Regards,
Amit
