CreoView JT Adapter enhancement
Creo View Adapter for JT right now supports only annotations visibility & orientation in a JT Part Capture (View State). It does not support conversion of
  • Cross Section
  • Explode
  • Pan-Zoon (View Port)
We need this ability to continue to expand our business usage of Creo View in a unified Windchill environment without requiring Siemens software (VisMockup).
2 Comments
SangminNoh
3-Visitor
Among the three items, 'Explode' is absolutely necessary.
Currently, Exploded View information in the JT file is ignored, so it cannot be used.
VB_10264264
1-Newbie
Loading JT file received from German OEM in Creo View MCAD. Result:
- No PMI's visible
- No weld points, RPS points, measuring points visible (geometry)
- No material transition (geometry)
- No bonding (geometry)
Notice: PMIs not visible in examples of other OEMs as well
Solution to exchange JT data with OEMs urgently needed!
