CreoView /// Offset X-sections should show in "shaded with edges" appearance mode
CreoView should  be able to show an Offset X-sections in "shaded with edges" appearance mode, just like in Creo Parametric.
3 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you @NicolasBourgeoi1 for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
For your information, here is an example of a well documented idea for Creo Parametric: Config option to ONLY save imported images in draw... - PTC Community
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
NicolasBourgeoi1
Hello @olivierlp
  • Watch making industry, High Jewellery – I’m a CAD/CAM & PLM Manager
  • CreoView 8.1
  • Creo Parametric 7.0.7
  • CreoView users can’t visualize “Offset X-Sections” when working in "shaded with edges" appearance mode.
  • Sharing Creo Parametric 3D models containing “Offset X-Sections” with other departments using CreoView
  • Normal use of a visualizing tool that has been pushed to the front by default
  • Do not have to explain to CreoView users that they can’t visualize the “Offset X-Sections” because it is a limitation of the software…
Best regardes
Nicolas
olivierlp
Community Manager
Thank you for the clarifications. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
