1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Industry
2. What product and version are you currently running?
CreoView 6.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
We need to control colors when DRW is opened from local/network drives. CreoView doesnt follow syscol or pentables as we know https://www.ptc.com/en/support/article/CS165682
Should not be such problem to add the same color management like in Creo. Now in CreoView we can change background color only which is not enough. We need full color control to avoid crazy colors when DRW is opened locally.
