Direct interface to Schematics internal and central library database
Schematics requires the input of many items for the central library that are merged into the internal database and must agree with each other.  The input routine (via CSV files) do not let the central database check each item until everything is loaded.
A direct interface that can interact with the internal and central library can verify integrity and let you modify the new item as needed.
1 Comment
PTCModerator
Emeritus
Status changed to: Under Consideration
