We are currently using Windchill 11.2 and I am an admin at one of our many design facilities.
The problem we have is with publishing family tables which drive configuration/geometry of components based on their location for a specific use on a machine. One specific assembly cannot be published as a positioning or extended positioning assembly because the family table instances are driven through a top level assembly which is not recognized by the adapter.
Having this addressed would allow us to view configured machines through options and variants as well as looking at structures and building work instructions in Windchill.
