Instead of perform design check outside the .prt or .asm, it could be good to have an apps that have the same features of PTC Creo View Design Check.
With this embedded direly inside the creo model, the designer could have access to the review without opening creo view. And make the update in line with the request.
It could be just to have an apps that open the model in a geometric simplification mode and have annotation and measurement possible.
