Enable Creo Parametric to read in External Model Accuracy and Use Start Part Templates
Currently, the software for Creo Parametric 4 will NOT read in external model accuracy when Use Templates is Checked.  The software assumes you want to use the model accuracy in the start parts if the box is checked an d basically ignores the model accuracy setting.  This is a bad assumption as we want to match the model accuracy for best results from the import model while retaining all other start part features(datums, layers, relations, attributes, simplified reps, view orientations, materials...the list goes on).
Reference PTC Case C14869029
With the settings as highlighted below, I want the model accuracy to match the external model.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
