Enable Save as STL for CreoView Profession
there is an open opportunity for the proffesional version of Productview.
As I understand the Productview version is able to save/export into STL. That's the reason for customers buying this product in the past.
Since Creo Elements/Pro 5 an import into ProductView wasn't impossible and the customer had to have invest in CreoView professional.
Which means additonal costs for the new product and the maintenance cost.
The good thing was that the customer now ware able again to open the data from ProductView Standard 9.0 CreoView Professional.
Unfortunately after initial purchase of productview for export to STL update to CreoView Profeessional customers aren't able to save as STL.
This option is fully missing in CreoView and degraded the product under the function level of ProductView.
It doesn't argue the 2 times additional costs for the new product and the mainenace without a solution in getting back the former functionality.
For the customers it means double-dealing and they won't accept this behavior.
Solution:
Only a quick workaround can help keeping the customer by trust in PTC strength.
Best regards,
Juergen
2 Comments
ptc-4416826
1-Newbie
function available in older versions should be removed from new one only with notation in read first.
It isn't helpful keeping customers allone with the situation what works in the past must not work in all future.
PTCModerator
Emeritus
Status changed to: Archived
