Enable ability for User Defined Simplified Reps to be included in Creo View Publishing
Currently, User Defined reps do not propogate to higher level assemblies when publishing to Creo View (See TAN 147488: https://www.ptc.com/appserver/cs/view/solution.jsp?&n=147488).  That means that to get user defined simplified reps into Creo View the user is forced to re-create every simplified rep at every level.
Please enable Creo View adapters to utilize the functionality already available in Creo Parametric and propogate user defined simplified reps to higher level assemblies when publishing to Creo View.
3 Comments
BillRyan
Thanks for entering this.  Same idea also located here...
http://communities.ptc.com/ideas/2548
BillRyan
Domingo, I believe most of the functionality is now available in CV3 M30 object adapters.  Check out my comment on idea 2548 noted above.
PTCModerator
Emeritus
