When working with large context in Creo Illustrate it is often necessary to check the surrounding of the parts in the scene. Today when switching between figures, SBOM and showing/ hiding parts the 3D figure is automatically updated.
This can result in data loss in the 3D figure and work needs to be done again.
Suggestion:
