Enable the name of a member to be set as a Parameter in Creo Schematics using the membermap file
Currently when a dataset is applied to an object in Creo Schematics, the name is set to the value as specified in the membermap file.
It would be useful if this name could be set as a parameter, which could then be derived from the parent artifact or somewhere else, rather than having to be explicitly defined in the membermap. This would be particularly useful in multi-level group shapes, possibly where there are multiple connectors contained within a group.
To enable this, the name format of group members needs to be kept as Autogen when a dataset is applied, rather than always being changed to Free Format.
1 Comment
PTCModerator
Emeritus
Status changed to: Under Consideration
