The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Enviroment variables support in paths for Creo Schematics
When defining Directories File>Options>Directories for template etc and for Central Catalog Design>Catalog one would benefit the ability to refer environment variables in paths rather than having to write full paths for each user.
i.e when setting the CSV directory, one could use:
  • %SCHEMANTICS_PATH\csv
The goal is to have similar functionality what is currently in Creo Parametric, where you can state paths using environment variables in config.pro.
This would help system administrators to create start scripts that sets the environment variables on the fly.
C13485512
3 Comments
clewis
3-Visitor
To deploy Creo Schematics into a global environment this kind of fuinctionality is almost a requirement. Another way to do this would be to edit the creo_schematics_defaults.bin on the fly with a script but the file fails if you try to do this crashing Creo Schematics.
Either method would work OK but the original idea of the file supporting env variables would be prefferred.
PTCModerator
Emeritus
Status changed to: Under Consideration
Alex_Y
Status changed to: Delivered
Delivered in Schematics 9.0
