Issue: After editing the business process Standard(s) used for Creo Illustrate any existing Illustration will not adopt the newly modified Standard. To get the new Standard a new Illustration must be created. There's no means for updating/editing the existing Illustration to use the newly modified standard.
Business case: Business processes are always changing and it's likely that any Illustration affected by a process change will require modifications. If the process change involves editing or adding content to the Illustration Standard then existing Illustrations need to be modified to adopt the current Standard. Having to create a completely new Illustration just to adopt the modified standard is unacceptable.
Request: Change Creo Illustrate functionality to permit Illustrations to adopt/update any modified/current process Standard.
Ref PTC article: CS266047
