The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Export 3D-PDF only what is visible in Figure
In creo Illustrate 5.1 if you export a 3D-PDF from a figure , it exports the entire assembly.
This is an issue when you have an entire machine, and a figure of for example a coupling.
Exporting the coupling instruction on a figure results in a large size PDF with all the part hidden.
These hidden parts can be set visible, and so IP of the design shown as well.
Please add an option only to export the visible parts of a figure to 3D-PDF.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
