Provide the ability to compare different versions of assemblies. But when comparing different assembly version components and sub-components geometry should be comparable. In the current Creo View 2.0 version user can compare Part Geometries but it comes to assemblies only features created at assembly level can be compared and all component/sub-assemblies are ignored.
