The 3D Connexion properties window pops up every time the user performs certain function in Creo View such as RMB on a component > Open in new window.
Please fix this behavior so the window does not pop up.
Here is the discussion on the 3D Connexion forum:
http://www.3dconnexion.com/forum/viewtopic.php?f=25&t=4710
PTC Tech Support case number: C11917936
