Fix the big regression of Creo Illustrate 6.0 in comparison with 5.1 (about Windchill)
Article CS262259
In Creo Illustrate 6.0 ptc removed the support for Windchill Workgroup Manager.
We can use only Direct Connection now.
I tested some hours this connection and I think that It's a big regression.
Our users add in the workspace Illustration sources to import.
They add in the workspace c3di and illustration sources to change.
With Direct Connection they can't use the Windchill Search, they have to browse Windchill folder (where there are thousands of files) seeing only the file name and not other info like number, name, ibas).
In my tests the checkin misses the relation with the illustration source...then I can't see if the source was updated...
For us this feature (Direct connection) is not usable and not acceptable.
I'm asking to review this change asap or we will use 5.1 until supported and then we will think to change software for illustrations.
Nicola
P.S.: I tried to open a case without success (C15160287)
2 Comments
Kristof_D
ngiacom
Done, thanks.
