Flexible Inventor assembly is not published correctly by Creo View Adapters
Currently Creo View Adapters cannot publish inventor flexible assembly correctly
Steps to reproduce:
    1. In an Inventor assembly, make a sub-assembly “Flexible”
    2. Re-constraint a part of the flexible sub-assembly and save
    3. Publish the assembly with inventorbatch.bat or inventorpublish.bat
Expected behavior:
    Representation should same as the assembly in Inventor
Observed behavior:
       1. representation in Creo View is not same with the assembly in Inventor
       2. It seems that the “Flexible” is ignored by Creo  View Adapter
1 Comment
olivierlp
Community Manager
Status changed to: Archived
