I want to correspond to match each system ID of the new part and old parts in the Creo Illustrate.
In the case of one part is changed its shape in 3D-CAD(ex. modeling), the part's shape in Creo Illustrate is updated as same as that 3D-CAD automatically, normally.
However, if the old part's system ID is not matching with the new part's system ID(ex. : the New part is created from scratch but not changed old part's shape), the Creo Illustrate does not recognize that the new part is equal to old part.
Even if these parts name is equated each other, it is no use.
Then, If I had already created several figures, I should be reworked to these figures once again in the Creo Illustrate.
I think that is hard and time‐consuming work.
So, I think more better that Creo Illustrate has expedients of the matching of arbitrary system ID.
And, I hope it.
