I want to delete parts directly from sBOM tree and viewport in Creo Illustrate.
Is there any good way?
Because...
I sometimes find unnecessary parts or assembly on the sBOM tree or the viewport in Creo Illustrate in to make the instruction illustrations of moved parts etc.
Under the circumstances, these parts could be only set to 'unload' at sBOM tree, and could not be deleted by select the part in the viewport.
Above 'Unload' not affects to other figures.
So, I want to delete these parts directly from sBOM tree or in the viewport.
Currently, I want to delete the parts from Creo Illustrate, I need to delete these from eBOM tree, now.
However, if I keep 'state of selected those parts' in viewport or select indicating at eBOM tree, those parts position are reset to default in viewport by selecting the '構造を編集'.
And I lose the unnecessary parts in the sBOM tree from the tree closing all.
If that happens, the unnecessary parts found again is very difficult in the eBOM tree.
