The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Have Schematics look at the file defaults when doing file operations.
0 Kudos
Presently, when you do an operation that needs to look for a file (data table updates and other items) the program defaults to the My Documents folder instead of using the many folders set up in the options-Direcories settings.
Support response is that the folder choices will be correct after you have navigated to the first one.
There are 20 file directories that the program wants identified, please use the work we did.
2 Comments
JimBarrettSmith
olivierlp
Community Manager
Status changed to: Archived
